I'm in progress of repairing the old EzGo Golf Cart that I bought to be used as a yard mule around the acreage. It's an oldie, but a cheapie. Perfect for my needs. So that is an indication of my expectations of the cart. Not a road use vehicle by any means.
I have found that one side of the rear axle axle shaft has had a bearing that must have been bad for years. Chewed up the axle in the bearing surface and seal surface, which I think are likely the same OD. Or should be. So the question is can I weld up the worn area and then turn down the weld surface to get a useful axle shaft? I can weld MIG, TIG, Braze, Arc, pretty much whatever process I would need. Or would I be best off to take it out and have it Flame Welded? Not sure if that is correct name of the process. I once had a shaft done that way, it seems that they put the shaft in a lathe and added powder as it was heated. Seems like that would probably cost too much these days for this unit.
Of course finding a new or better a used axle would be best, but not sure that will happen. After all it's an 81 Golf Cart.
Thoughts on this issue?
I can get pictures tomorrow. But it's just like a car axle shaft only very small. Probably 20 inches long 1 1/4 Dia.
