I needed a way to hold material in any position to practice out of position welding. I used 3/4" pipe and 1018 to build this. I made the T-bolts out of 3/8-16 s.h.c.s. and 5/16 rod. The clamp is able to hold up to .750" material.
That is pretty much what we use at are school only the base is a welding table. I made something using angle for vert. and over. when I was getting readdy to cert.in TIG. your is much nicer than mine. Great work.
