- Sep 22, 2010
- 898
So I was wandering around one of the tool stores in the big city and noticed a neat welding station put out by Miller. http://millerwelds.co/arcstation.
Then I got thinking. I picked up a blade from some big scraper back awhile ago. 20 " wide x 8' long x 1" thick from the scrap yard.
It has a series of holes down the centre, that would make a nifty weldng bench. The plate is hardened steel to boot!
So I am using 2-1/2 x 2-1/2 x 1/4 HSS Tube for legs, only had enough for four legs, one for each corner so hopefully the plate is stiff enough to support any load. Each leg has a Footmaster GD-100F levelling castor, good for 1650 lbs each so if I am correct should be able to load it up nicely.
Sorry can't take nay pictures till GF gets back from her sisters wedding in Guelph this weekend.
Walter
Walter
