Weekend welding project Third hand
churchjw
Oct 4, 2011
727
Had seen one of these at the local high school's welding shop so I finally took the time to build one. Ok I guess there are 2 of them.
The uprights are 16" tall 1" pipe. The balls are 1" I got from Enco on a huge sale. I put them on the surface grinder and ground a .250" flat spot to weld on the rods. The rods are .375" O1. The flat plates are .375" * 1" * 4". I have to 2 more of the bearings to weld up another style of clamp for the ends if I need. The sockets for the balls are cut .250" deep with a 1" ball end mill. If I did it over I would cut the sockets shallower. This would give them more movement. Not that I have found a position it would not adjust to yet. I originally did the sockets that deep to get more surface area for more holding power but I think it was over kill. The unit is very ridged with only a snugging of the allen bolts. Next step is to tool black everything. I don't want to paint it so it conducts electricity.
Jeff
Cool project. The only thing I would do different is make the Allen screws toolless, by welding some T handles onto them, like wing nuts, for quick easy set-up.
I originally was going to put T handles on them. I even have the stock cut but I am not sure they would not get in the way. I am going to try it for a bit like this and if its a pain I will weld the handles on. I think in the long run you are right it will be the better way to go.
Jeff
Final pictures for them finished. Had to get the tool black on them. Used them to weld up a project this weekend. Worked better than I could have hoped for.
Way too slick and high class for a bunch like us, send it to me and I'll "dispose" of it properly.. Just kidding, looks like a great tool to have in the shop when your helper is gone.
Bob
excellent tool, I will have to try something like that when I get some time
Awesome project, thanks for sharing with us!
Can you explain the "tool black" a little more please? Also, what clamps did you use (around the pipe)?
Jeff, excellent execution of and old idea. I believe yours are the best I've seen. Pete
The tool black is just a chemical you put on steel to help stop rust. It basically forms an oxide layer. I got mine from MSC years ago.
The vertical adjustment is from 2 collars I had left over from another project. They are stainless but I already had them made.
Jeff
100_7758.JPG 100_7759.JPG 100_7760.JPG 100_7761.JPG View attachment 95453
Jeff-
I want to make one of these jigs, but I don't have a milling machine or a lathe.
To cut the sockets for the balls, could I chuck one of these ball end mill things in a drill press and cut the sockets that way, do you know?
If so, what speed in RPMs might I need to use for a cutter like that in mild steel? I'm only a wannabe "machinist" and I'm wondering whether my drill press has the proper speed...
Thanks in advance for any help.
