There seems to be a wide consent that for cutting aluminum, WD40 is the choice of instead of other cutting oil such as tapping oil. May I know the reason? WD40 coming out from spray cans contains a lot of solvent, does it have any negative effect ?
I buy it by the gallon, and use a squeeze bottle. WD40 itself is a solvent. I have spray bottles (zep containers) for large coatings (not machining).There seems to be a wide consent that for cutting aluminum, WD40 is the choice of instead of other cutting oil such as tapping oil. May I know the reason? WD40 coming out from spray cans contains a lot of solvent, does it have any negative effect ?
Alcohol ? this is the first time I hear it. My understanding has been that cutting oil reduces heat , minimizes sticking , prolongs tool life and helps the flow of chips although there are mixed opinions on these. I have even heard that NOT using cutting oil makes tools cooler but alcohol used as cutting fluid is really new to me.I bought a gallon of WD40 and just us an acid brush to put it on. Much less in the air than a spray can. I think Stefan Gotteswinter uses alcohol. There may be more fire risk with it.
yep, many use it. it acts like a super cooler, more so than cutting oil. Not as high in the lubricity, but since it is a liquid it does aid in that respect.Alcohol ? that's the first time I hear it. My understanding has been that cutting oil reduces heat , minimizes sticking , prolongs tool life and helps the flow of chips although there are mixed opinions on these. I have even heard that NOT using cutting oil makes tools cooler but alcohol used as cutting fluid is really new to me.
