I don't currently have a lathe. But I have a mill/drill. I need to bore out some pipe to take a bearing.
I was going to clamp the pipe vertically to the table. My mill has a MT2 spindle and has a draw bar.
I've looked into boring bars but haven't seen any that are small enough in diameter.
I've looked into end mills to do a plunge cut; but haven't seen one in the size I need. Maybe a 1-3/4" that has been resharpened?
I was looking at 2" DIA pipe with 1/4" wall. The bearing is a 42mm(1.654") bearing. It only needs to be a light press fit. Pressed in by hand even. Just so it's not loose.
I know a lathe would make quick work of this; but I just don't have one.
Can this cut be done on a lathe? What setup would do it?
I've also looked at a vise that will rotate.
The pipe is 3" tall. This is a picture of the manufactured part:
