- Feb 7, 2012
- 550
I am working on a steel cannon and have managed to drill into it the full needed length of 15.50" - but only with a 7/16" extended drill. Took quite awhile going .50 " at a time and then clearing chips and re-lubricating with cooling juice. My problem now is how to complete the larger bore size to that length? I stepped up with a 5/8" / then 1" / and finally a 1.125" shorter drill getting in almost 6.0" total, but all these larger drills are very short, and I'm not sure how to extend them safely. Boring bars might be an answer, but right now at 7/16" I have nothing long enough or small enough to fit into the existing hole. Any ideas / suggestions on how to proceed with this task would be appreciated. I'm working with an older Heavy 10 with a 4' bed, so reach is not an issue as long is any tool doesn't exceed 16" - but I would thing there would be a lot of flex in a boring bar that long and narrow enough to work in the existing hole....
Thanks in advance....
