- Jan 30, 2017
- 261
I have purchased a sheet of 1/4" thick F1 felt to make new wipers for my lathe. Should I cut the new felt to be a little longer than the brass wiper housing?
Yeah, I bet McMaster is wondering why there was a rush on 1/4" F1 felt here lately.Yup, I did the same thing as Ken, left about 1/16" to compress in. I was told F5 is best for way wipers though. I also have 1/4" thick felt, purchased from Mcmaster.
I also bought some wicking felt, too, for using in some of the Gits oil cups I have on some of my machines.
If you go to McMaster-Carr's website and look for the section on felt. They give very good definitions for the F numbers as well as the different types of felt they offer. Some of the types, they even mention the applications of the felts. It seems like every one likes to use the F-1 which is a hard dense felt for way wipers. All the years I've made replacements I've used a very soft low density black looking felt to make felt wipers out of. The thickness was double so it had lots of compression when assembled. Never saw where it made a difference. Of course, it makes a difference, you want the felt to "wipe" and lubricate while the slide is moving. KenI've looked around and can't seem to find what the F number of felt actually refers to. I know that it's the hardness and softness, but what is the
difference between F1 and F5 for instance? Thanks for the Zoro tip, I've never done business with them. I use McMaster Carr a lot (at least for me).
Thanks.
