Hello again:
I've been re-building/scraping this small Chinese mill. It does not have an oiler pump. It is very difficult to oil some areas of the ways (especially under the table). I know that way oil is typically used on mill ways, while grease is used on surface grinder ways. I could install an oiler system on this mill, but it sure would easier to use some sort of grease. Does anybody know of a grease that can be used especially for this application? I can see how it could be pretty nasty to restore an old mill that used grease instead of oil
I looked around and it seems that some older machines used grease rather than oil and some of the newer Haas machines reportedly use grease.
I've heard that grease is used on grinders to keep the abrasive dust off the ways. Why can't this also work well for a mill?
Mel
Mel
