LOL Dave
The funny thing about this engine, back when I was in high school, must have been 16 or so at the time, I was researching a paper I was writing at a library in a nearby city and stumbled across the article. Then after I got home I found a copy of the original print in a file cabinet of stuff my dad had cut out of old Popular Mechanics and Popular Science, etc. Either way I have the original article cut out of the magazine. Long story short I started building the engine back then out of all steel, didn't have no brass around to speak of. I gave up after making the column and the end caps as well as the block for the entablature - right around the time I broke my 2-56 tap off in the 4th hole. I couldn't afford another tap for a while, though I eventually replaced it. Fast forward several decades I started up again, and would't you know it, broke the same tap off in the same exact hole :-( Least this time I could afford the replacement. Rudy was probably building that engine about the time I was born.. I was a little over a year old when Popular Mechanics published that article.
So you might say that I'm finally going to finish what I started about 30 yrs ago. I started the engine using the Popular Mechanics article which is the opposite of the book (which I bought this past fall). It has lots of writing, but no detailed drawings. I doubt I would have been fully successful just with the article. But if I would just read the article I might quit making bumbling mistakes like drilling and tapping all the holes in the cylinder block *before* making the parts that are to be screwed onto it. Somedays I'm the village idiot when it comes to sequencing things - I needed to make the cylinder to make it so I could fit the end caps, but not drill the holes until I transferred the holes through the caps. I'll have to see how accurate I can get the holes, if they don't quite line up I'll remake the cylinder. Got lots of metal and umm... I made a couple of other mistakes on the cylinder that I had to correct with some silver solder and a small brass plug.
If I ever get this done it will be my first working engine of any kind.
Here is a question for you to ponder.. Since we are both making the same engine, should I post my progress and experiences in this thread or start a new thread? I don't want to steal any of your thunder so I'll let you make the call on that. I'm fine either way and it makes sense both ways as well.
Sincerely
Mark R. Jonkman
