A fork lift is one of the things on my wish list. The Bobcat does alright for most lifting jobs under 1,000 lbs but sometimes I really need a fork lift.
Oldmachinist,
Very nice saw. Does it have the butress thread half-nut on the vise clamp screw? I have the WF Wells A-7 and like it very much. The butress half-nut on mine is worn and I have been putting off making a new one. It's on the to-do-list though.
jumps4,
Charley almost talked me into going halves on a fork lift but you need to have all paved/smooth surfaces to keep all the wheels on the ground and not stick it. I guess I will just have to live with a tractor mounted front end loader. Also don't have the space to park a forklift inside when not used.
Benny,
Yes it has the buttress thread half nut. The one on mine looks new. Have you priced a new one from W.F. Wells? They say they still support saws as old as from the 40's.
The reason I've put off buying a fork truck is I want a rough terrain one. There's one nearby that I haven't talk the owner into selling yet. I'll get it some year when he's tired of storing it.
you might as well all go in together and buy a semi and trailer, probably a low rider flat bed with a 100 ton winch for now untill something larger comes along....
:drink2:
steve
Oh it's definetly a good saw. It was very noisey when I got it so I replaced the bearings in the blade wheels, and variable speed drive, adjusted the drive gear mesh and gave it a good cleaning. It runs quiet and cuts great.
