- Sep 22, 2010
- 7,222
from WEWilliams.net
"A place for me to stick my stuff!"
These files are scans of original South Bend Lathe documents in my archives. (Archives sounds so much better than 'pile of old books' doesn't it?) Anyway, you will need Adobe Reader to view these documents.
1914 How to Run a Lathe 3rd Ed 300 dpi 2.7 Mb 1914
How to Run a Lathe 15th Ed
300 dpi
3.0 Mb
1917
First Year Lathe Work
1917 Ed
300 dpi
5.0 Mb
May 1918
Catalog
55
300 dpi
4.0 Mb
1920
Machine Shop Equipment for Vocational and Industrial Schools
2nd Ed
300 dpi
4.4 Mb
1920
How to Make an 8-inch Bench Lathe in the School Shop
1920 Ed
300 dpi
4.2 Mb
1925 The Correct Way to Machine Oversize Pistons Bulletin No 85 400 dpi 4.5 Mb
1925 The South Bend Method for Refacing Valves in the Lathe Bulletin No 86 400 dpi 4.2 Mb
1925 South Bend Shop Methods for Electrical Service Stations Bulletin No 87 400 dpi 4.3 Mb
1925 The South Bend Method for Reboring and Regrinding Cylinders in a Lathe Bulletin No 89 400 dpi 4.1 Mb
1928 New Model South Bend Brake Drum Lathe Bulletin No 29 400 dpi 16.0 Mb
1928 South Bend Machine Shop Course Bulletin No 55 400 dpi 8.0 Mb
1929 Auto Mechanics Service Book No 66 400 dpi 14.9 Mb
1929 South Bend Hand Book No 33-C Showing Shop Kinks for the Auto Mechanic Hand Book No 33-C 400 dpi 15.0 Mb
1929 South Bend Hand Book No 44 for the Mechanic Hand Book No 44 400 dpi 15.1 Mb
1930 South Bend Hand Book No 33 for the Auto Mechanic Hand Book No 33 400 dpi 14.9 Mb
1931 Latest Shop Practice Bulletin No 30 400 dpi 5.8 Mb
1931 The Small General Shop Bulletin No 50 400 dpi 3.9 Mb
1932 How to Grind Valves in the Auto Service Shop Bulletin No. 1 600 dpi 2.1 Mb
1932 South Bend Lathes for Auto Service Shops Circular No 36 400 dpi 2.9 Mb
1933 How to Make Bushings in the Auto Repair and Electrical Shop Bulletin No. 7 600 dpi 1.4 Mb
1933 How to Test and True Differentials in the Auto Repair Shop Bulletin No. 5 600 dpi 1.4 Mb
1935 Interesting Installations of South Bend Lathes Book 71 600 dpi 19 Mb
1935 Repair Parts for South Bend Lathes Bulletin 19-B 400 dpi 5.4 Mb
1936 How to Grind Valves Bulletin 1A 400 dpi 2.3 Mb
1936 How to True Armatures Bulletin 2A 400 dpi 2.1 Mb
1936 How to True Brake Drums No 4A 300 dpi 2.0 Mb
1936 How to Test and True Differentials Bulletin 5-A 400 dpi 1.6 Mb
1936 How to Bore Rebabbitted Connecting Rods Bulletin 6-C 400 dpi 2.2 Mb
1936 How to Finish Pistons Bulletin No 9 400 dpi 2.2 Mb
1936 What to Make on the Lathe Bulletin No. 34 300 dpi
1.0 Mb
1936 How to Cut Screw Threads in the Lathe Bulletin 36A 400 dpi 3.5 Mb
1939 Farm Mechanics in the School Bulletin No 31-A 400 dpi 4.9 Mb
1941
Manual do Torneiro
38th Ed
300 dpi
6.7 Mb
1940
Manuel Pour l'Usage du Tour
37th Ed
300 dpi
6.7 Mb
1947 Curso Elementry de Instrucoes para o Ensino de Aprendizes de Torneiro Mecanico Livro 30-P 600 dpi 12.7 Mb
1953
Manual del Tornero
52nd Ed
300 dpi
6.3 Mb
1954 School Shop Planning and Specifications Manual 400 dpi 50.0 Mb
Commercially Available Hardware Items
Form 1178
300 dpi
1.0 Mb
How to Install and Operate a South Bend Precision Vertical Milling Machine Bulletin 6012 400 dpi 2.3 Mb
NON-LINEAR SCREW CUTTING ATTACHMENT - FOR 9-INCH SOUTH BEND LATHE 400 dpi 3.0 Mb
Belt Splicing Instruction
Bulletin No 600
300 dpi
3.0 Mb
Oiling Chart for 9 Inch Workshop Lathe Model A
C-161
300 dpi
0.1 Mb
9 Inch Horizontal Adjustable Motor Drive Bench Lathe
EP-100
300 dpi
0.1 Mb
June 1978
Jeff Swayze Collection: South Bend Lathe Price List
1.5 Mb
Jeff Swayze Collection:South Bend Lathe Accessories Catalog -
7.6 Mb
MetalWorking.com: South Bend 7" Shaper Model CS100
0.6 Mb
MetalWorking.com: South Bend 9" Lathe Model CL 670Z
1.3 Mb
Last Update 04/18/2008
300 dpi
3.0 Mb
1917
1917 Ed
300 dpi
5.0 Mb
May 1918
Catalog
55
300 dpi
4.0 Mb
1920
2nd Ed
300 dpi
4.4 Mb
1920
1920 Ed
300 dpi
4.2 Mb
1.0 Mb
1941
Manual do Torneiro
38th Ed
300 dpi
6.7 Mb
1940
37th Ed
300 dpi
6.7 Mb
1953
Manual del Tornero
52nd Ed
300 dpi
6.3 Mb
Form 1178
300 dpi
1.0 Mb
Bulletin No 600
300 dpi
3.0 Mb
C-161
300 dpi
0.1 Mb
EP-100
300 dpi
0.1 Mb
June 1978
1.5 Mb
7.6 Mb
0.6 Mb
1.3 Mb
1925 - South Bend Shop Methods for Electrical Service Stations - Bulletin No 87.pdf4.3 MB · Views: 1
1925 - The Correct Way to Machine Oversize Pistons - Bulletin No 85.pdf4.5 MB · Views: 0
1925 - The South Bend Method for Reboring and Regrinding Cylinders in a Lathe - Bulletin No 89.pdf4 MB · Views: 0
1925 - The South Bend Method for Refacing Valves in the Lathe - Bulletin No 86.pdf4.1 MB · Views: 0
1928 - New Model South Bend Brake Drum Lathe - Bulletin No 29.pdf15.8 MB · Views: 0
1929 - South Bend Hand Book No 33-C Showing Shop Kinks for the Auto Mechanic.pdf14.7 MB · Views: 1
1930 - South Bend Hand Book No 33 for the Auto Mechanic.pdf14.3 MB · Views: 1
1932 - How to Grind Valves in the Auto Service Shop - Bulletin No. 1.pdf2.1 MB · Views: 0
1932 - South Bend Lathes for Auto Service Shops - Circular No 36.pdf2.9 MB · Views: 0
1933 - How to Make Bushings in the Auto Repair and Electrical Shop - Bulletin No. 7.pdf1.4 MB · Views: 0
1933 - How to Test and True Differentials in the Auto Repair Shop - Bulletin No. 5.pdf1.4 MB · Views: 0
1935 - Interesting Installations of South Bend Lathes - Book 71.pdf18.8 MB · Views: 0
1935 - Repair Parts for South Bend Lathes - Bulletin 19-B (1).pdf5.3 MB · Views: 0
1935 - Repair Parts for South Bend Lathes - Bulletin 19-B.pdf5.3 MB · Views: 0
1936 - How to Bore Rebabbitted Connecting Rods - Bulletin 6-C.pdf2.2 MB · Views: 0
1936 - How to Cut Screw Threads in the Lathe - Bulletin 36A.pdf3.5 MB · Views: 0
1936 - How to Test and True Differentials - Bulletin 5-A.pdf1.7 MB · Views: 0
1939 - Farm Mechanics in the School - Bulletin No 31-A.pdf4.9 MB · Views: 0
1954 - School Shop Planning and Specifications Manual.pdf49.2 MB · Views: 0
EP-100 9 Inch Horizontal Adjustable Motor Drive Bench Lathe.pdf101.1 KB · Views: 1
How to Make an 8-inch Bench Lathe in the School Shop - 1920.pdf4.2 MB · Views: 0
NON-LINEAR SCREW CUTTING ATTACHMENT - FOR 9-INCH SOUTH BEND LATHE.pdf3 MB · Views: 1
