Vortex dividinghead failing ???
ksor
Jan 4, 2012
108
Vertex dividinghead failing ???
Now I'm back on this project !
I have made a sketch/drawing but MAYBE I have some problems with that configuration:
1) will the bushing be fastened in the long run or will it loosen ?
2) because the bushing is PRESS FITED and then sawn at point B - will the two halfs then "pop out" and ALWAYS clamp the shaft (not drawn !)
Look here: http://kelds.weebly.com/vertex-delehoved.html last pair of Pictures !!!!
As always translation to the right under the menu line !
