Vise Sine Keys on MVN
SPICEMAN
Mar 15, 2018
18
Kurt had a great deal on scratch and dent DX6 vises. To line them on the table they use sine keys. In looking at Burke MVN specifications I find the table slots are 11/16" or 0.6875".
Sine keys listed various places spec out at 0.6870 but the one set I bought are closer to the 0.688" side of things.
My table slots measure more to be closer to 0.6873" so the keys do not fit the slots.
My question is has any one else seen this issue. The next smaller keys are 0.6245" so a bit of a drop. Any ideas on fixing? The darn keys are not cheap so buying another set to try is a bit hard on the pocket book.
He is talking about the little blocks the bolt to the bottom of a vise that sit in the T slots. They are supposed to align the vise. Supposed to that is.
You have a mill. Make them fit. That is what machinists do.
Already had that idea but more wondering why no fit in first place. Maybe 11/16 has changed over the years.
Many mills now have metric slot sizes. Maybe they're sized somewhere in-between metric and SAE to work in both cases.
In my experience, positioning keys like that can be cumbersome. For quick and dirty positioning they are fine but can get in the way when trying to do precise positioning. I have a 4" vise and when precision is needed, alignment to 0.0003" variance or less is not uncommon. Positioning keys aren't going to help with that level of precision. Also, they are not intended to help secure the vise; the clamping bolts do that job.
As far as the term Sine Key... I've never heard of that. I watched the Kurt video posted above but, there was no audio so maybe I missed-out on an explanation. I don't see how they can be used to form an angle. I wish there was audio on that presentation so I could hear Kurt's explanation.
Ray
I have always just made the keys to fit tightly in the vise body and snugly in the tee slots; the vise may not align absolutely truly, but that is seldom needed in normal machine work.
We have four Kurt vises all with fixture keys that fit snug.
We sometimes set up two or three vises on a Bridgeport and they will indicate within .002 between all of them
Also the height from table surface to the vise bed will have the same dimension
I would check the check the key-ways on your table some where the key-ways have not been abused!!
With normal use the key-ways can have nicks and other problems, you may need to shine the bed key-ways to get the fit you are looking for
Sine key are installed in round holes for setting fixtures
this a sine key for different key-way widths
A picture is indeed worth a thousand words; I have seen these before, had some, but never used them.
