Vfd
Scottlew
Nov 6, 2024
3
Hi guys anyone help with vfd xsy at1 can't get motor to run I don't understand what the parameters are giving me a headache
Ah, it would take a miracle to help you without knowing much more....
Please enlighten us
Hi,welcome to HM.
In order to get you an answer we need more information. Here are some guidelines that might be helpful:
Hopefully this information will enlighten you xys at1 4.4kw inverter 240v mains to 240v 3 phase permanent magnet synchronous motor 60hz 16755 rpm I'm trying to understand the instructions for parameters with a lot of difficulties
I do not see in the manual that the xys at1 is rated to run a permanent magnet motor. The VFD needs to specifically indicate it can run one.
  • VFD XSY AT1 Manual.pdf
