- Nov 28, 2021
- 70
I wired my VFD and have my mill up an running. Do I still need the reversing switch on the left side of the head or can I just wire the motor direct to the VFD since it does the reversing?
Oh I like switches. Thanks for the link. So it's not hurting anything to use the start/stop and reverse functions built into the VFD?You wire the VFD motor outputs directly to the motor. You use the VFD low voltage inputs through a separate switch to activate the run commands and motor direction. There is both what is called 2 wire control (which requires a continuous connection for the run direction), or 3 wire control which uses momentary switch for the motor on/off and a separate sustained 3rd input for reverse. I often use the switch gear below for the low voltage inputs, do not use the old rotary switch which is designed for high voltage switching.
Correct, using the VFD functions is preferred. Using the old high voltage reversing switch can easily damage the VFD if the VFD/motor is running when that switch is used.Oh I like switches. Thanks for the link. So it's not hurting anything to use the start/stop and reverse functions built into the VFD?
Ok then I am going to remove that switch and just wire straight to the motor. Is it okay to leave the VFD on all the time or should that be on a switch?Correct, using the VFD functions is preferred. Using the old high voltage reversing switch can easily damage the VFD if the VFD/motor is running when that switch is used.
Leaving the VFD on all the time should be OK, but I prefer to put them on a switch. That way, if a power surge such as a nearby powerline lightning strike occurs while you're not using it, the VFD is disconnected and unlikely to be damaged. Of course I knew people who unplugged their television when not watching it for the same reason, I never do that and my flat screen is more expensive than my VFD.Ok then I am going to remove that switch and just wire straight to the motor. Is it okay to leave the VFD on all the time or should that be on a switch?
Just ordered one thanksAlways on should be fine. I have switches in front of all my VFD's though.
These switches have worked well for me. They are affordable and pretty easy to mount next to the VFD:
https://www.amazon.com/gp/product/B01KLS09NI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Electrical transient analysis of surges is definitely a complex issue. Chances are pretty good that the closed switches (or the VFD without a switch) will provide enough low impedances paths to prevent hitting breakdown voltage across an open switch. If you get a lightning strike on the powerline on your side of the transformer, then all bets are off. Lightning strikes are also a very good reason you want single point grounding on your home electrical system. I don't know how many shops I've seen that are home wired with a separate ground rod for the shop. If lightning strikes ground anywhere in the vicinity, there is a huge potential across the two ground rods, and some hideous induced currents. Better to have only a single ground.I doubt a switch would help with a lightning strike, it's already jumping miles in the air, the few mm in a switch isn't going to slow it down
