- Nov 17, 2012
- 48
This week I purchased a used lathe and used mill. Both are 220v / 3 phase motors. I will be adding a 220v circuit to my garage with the hopes of getting both machines and running today.
But I need to figure out wiring, so that both machines can be powered by the 3HP VFD that I purchased, just not at the same time. That is, I will not be running both motors at the same time.
That's my question:
Is there a simple, safe way to wiring up the 3HP VFD to control both machines individually, using a main switch to toggle which motor receives power?
I have watched a bunch of videos regarding wiring up a VFD but there's not much out there on how to set up multiple motors on one FVD.
Someone I know suggested wiring both machines in series after the VFD and put a 3 phase switch on each machine to prevent power from getting to them unless switched on.
I'd love to get your opinions and ideas on how to wire this VFD safely (PDF link).
That's my question:
