I assume this is the correct forum to discuss VFD's. please correct me if I'm mistaken.
thinking about converting my 1940's Delta 17" drill press to a 3-phase motor with a VFD to control RPM's. I have absolutely no skills with electronics so have a couple of questions to start.
1. is the 1.5hp motor pictured a good candidate for this? my understanding is that you want more HP than originally as the VFD can cost power or torque. my current original Delta repulsion-induction motor is 3/4hp. the motor pictured may be more power than needed but is available locally at a great price.
2. I have done some reading on VFD's and see some that some are 115v single phase input and some are 220V single phase input. I have both 115 and 220V receps next to my drill press currently so can use either. is there any advantage or disadvantage to using 220V input?
thanks for any insight you can provide.
