Hello,
Trying to set up a VFD with a new Baldor motor and a old Hardinge cataract lathe.
Is it best to set the pulley sizes so at 60 Hz on the VFD the lathe spins at the middle of the range of lathe spindle speed? Then vary the frequency to vary the upper and lower speed of the lathe?
What is the typical range of rpms I can expect from a 1740 rpm motor w/ a TECO FM50-101-C? at 120 Hz is the speed double? What are the limitations of a motor typically? i.e. I would guess it would not be a good thing to make them spin twice as fast as they are rated to, or is there a limit on how slow you should make them spin?
If any one can help that would be great. Or point me at a thread that can answer these concerns. Thanks.
