- Apr 22, 2016
- 971
I have 4) XSY-AT1 VFD's and haven't had any trouble with any of them (oldest is 3 or 4 years old). The newest one (less than 1 year old) now is not starting when the shop ambient temperature is over about 75F. Works just fine in the morning and on cooler days but once the temp hits plus 75 or so, it will not start. Gives a under voltage error (I assume this means incoming voltage). I have played with parameters.
To me it acts like a component in the power supply section is sensitive to heat and the output of that section is too low.
I've checked incoming voltage and it is good @ 241 volts.
Any ideas?
Any ideas?
