Inspired by Mr. Pete, I decided to try installing the Vevor x-axis power feed on my newly acquired PM-833T. Short version: it is possible but you will lose some table access.
Longer version:
The mounting holes are a bit different and I didn't want to drill holes into the end of the table, so I made an adapter plate from 1/4" thick steel plate I had on hand:
A bushing to fit the needle bearing and leadscrew:
The unit was mounted at an angle to provide easier control access:
The drive gear collar thing was cut to length, key cut thinner, and shaft was shimmed 0.020":
It works!
The only downside I have found thus far is the table travel is reduced because the unit extends below the table, but, it is easy to take it off if needed.
Longer version:
It works!
