Hopefully this will help to clarify this for you, Pcmaker. I am attaching some pdf files here because I can't download them to the downloads section for some reason.
Several things to note:
- The data assumes you have a full sized industrial mill, which you do not. Therefore, I suggest you reduce the recommended speeds and feeds by about 20% or so.
- The process you're using matters. You can do Profiling or Perimeter cuts or Slotting cuts. The amount of the end mill's diameter or length you choose to engage affect the speed.
- The max depth you should use in a slot cut is the diameter of the end mill, so for a 1/4" OD end mill, you can cut 1/4" deep at a time. If you need to go deeper then make multiple passes.
- The max axial depth of cut, meaning the max amount of the end mill that is touching the work when doing profiling cuts, is 1-1/2 the diameter of the end mill. So, for a 1/4" end mill doing an edge cut you can engage up to 3/16" of its length max. This has to do with deflection of the end mill more than anything else. Carbide can take more but staying with this guideline works for most of the end mills you will use.
- The cutting speed varies with the amount of radial depth of cut when profiling and axial depth of cut when slotting. The deeper you go, the slower you need to go.
- Cutting speeds also vary with the end mill type - roughing end mills can go about 20% faster and feed about 20% faster.
- Feeds are for NC or CNC mills. For those of us with manual machines, feed per tooth means little. The best approach that I've found is to feel the end mill cut. At the right speed and depth of cut, feed so there is a slight resistance to the feed. That is, feed until you feel a slight resistance to the amount of force you apply to the wheel. This applies to all materials and you will quickly be able to feel and adapt to the cut.
When in doubt, slow down your speed and feed. Do not just use the end of your end mills to take baby cuts; this just wears the cutter faster.
When profiling/peripheral cutting, more flutes is better. When slotting, fewer flutes is better for chip clearance. Learn about high helix end mills for aluminum and use them.
Please, please buy some roughing end mills to do the bulk of your milling. Save your finishing end mills for finishing cuts. Roughers outlast finishers by a big margin and will cut faster and save you time and effort.
These are just general guidelines. If you have a specific application, contact the end mill maker and discuss your needs. Take notes on how you made a cut, what worked and what didn't work. Over time, you will have enough data and experience to feel comfortable with milling.
Also, do not be afraid to make mistakes; that is how we learn. Well, at least that's how I learn.
