- Mar 20, 2014
- 439
I have been reading some of the posts in this welding section, and one thing has come up a few times that confuses me (doesn't take much). You guys talk about using so many "amps" and a certian "wire feed speed". Now I have an old sears AC buzz box, that I've been using for years for my own bubble gum welds, and my knowledge consists of this "thicker steel means more amps and bigger dia. stick electrodes. Burn through-- lower amps" My son has a little Lincoln 125 plus mig welder with argon/co2 bottle that he uses for thin steel, and the only controls on it are VOLTS and WIRE FEED. Where do the amps (heat) come in? And if I'm burning holes, what do I turn down, or, in the opposite situation, (not hot enough) what do I adjust? Thanks, JR49
