Have an old - not sure how old - Vernon metal shaper. I believe Vernon was a brand affiliated with Sheldon. I've seen some Sheldon shapers that seem more modern but look very similar to my Vernon. One thing that tells me this is an old shaper is the stroke adjusement. Where some machines have an external stroke adjustment, to adjust stroke you need to remover cover on left side of machine (left as you face the machine) and loosen a 1-7/16 nut which has a mechanism to shorten or lengthen the stroke arm. As you can see in pictures there is quite a bit of wear in the channel (not sure proper term) that the nut block (again not sure proper term) clamps/tightens to. I'm wondering if I should take apart and mill the work channel area to make smooth? Or if it's necessary.
Another indication of the machine's age is, from what I can tell, it does not have a clutch. Only way to run the ram is to turn on the motor. It does have 2 speed ranges, but no clutch mechanism. Is that just the way it is for older machines? If so does that give anyone an indication of age?
It's design is another indication of an old machine. The ram casting is styled in almost a gothic old architectural style. Something not bothered with in newer machines.
Also, the one picture shows the name plate. But in the area/fields where the model and serial number would normally be stamped - they're blank. There is a small brass plackard with #730 stamped on it. This is fastened to the left side of the machine (again, left as you face the front of the machine)
My quesions are:
1. Should I attempt to repair the wear in the stroke adjustment mechanism?
2. Is/how this machine related to Sheldon's, and how old it might be.
3. Has anyone modified or have ideas to add a clutching function? I do not like turning the motor on/off so much; especially when making small adjustments needed to line up the channels to adjust the stroke.
My quesions are:
