- Dec 12, 2011
- 132
I am disassembling and cleaning the 10F babbit head lathe I just got and have a couple questions on the spindle assembly.
The previous owner mentioned he had the spindle out for some obscure reason as he also said he knew very little about lathes.
I am not sure if everything is back as it should be as I know there is a washer (9-89) missing.
So , #1 does anyone know the thickness of this washer and is it located against the bearing in the picture (inside the head stock) or against the spacer (outside the head stock) ?
#2 is the bearing in the picture facing the right way ?
#3 how tight is the adjustment collar (9-39) on the end supposed to be ?
There seems to be a lot of wear on the end of the headstock on this end but not at the chuck end.
Any help would be appreciated .
