- Feb 16, 2019
- 15
Now that I have the lathe, I'm still not finished cleaning it up. It has had aluminium packed in places for years, just started getting it cleaned, and oiled up.
I noticed while cleaning the back it looks like something big attaches to the back. Would that have been a mill attachment from one of the smaller v series lathes?
I didn't get anything with this lathe other than a 8 inch 3 jaw chuck with usable jaws. I can't find the name on the chuck to order jaws.
This lathe sat in storage for the past 5 years or so. The previous 15, or 20 years it was used to cut aluminum parts in half to reveal a feature to be measured. When parts were still available someone had ordered or had made custom jaws being that only 1 part was being cut down. The jaw part that goes into the scroll may be usable, but the work holding part is not. i looked on Ebay the jaws available for work holding would not fit the tooth pattern on my scroll side I think that the chuck is original to the lathe. Would the chuck be labeled somewhere in the back that can't be seen until the chuck is removed?
I checked the gears and I think I have all of the metric gears. I say think because I have not removed the small gear to check It yet.
Also have a live center with small tip. Doesn't look used but is browned like the chuck. Twisting with my fingers feels to be good at low speed, not been able to check it at speed for bad bearings yet.
