- Nov 14, 2014
- 851
Hardly anyone posts here, but hopping someone will look at this forum and have an answer...
I have a 1950 SM Utilathe, (12x48 gear head) with noisy and worn low speed gears in the headstock. The worst offenders run the lathe at 65, 100, 150, and 250 RPM. So basically all the HSS cutting gears.
I am thinking about changing out these gears to improve extend the life of the lathe.
I've previously taken the lid off the headstock and removed the drive shaft bearings. However could not get the shaft/gear assembly out of the headstock casting. The length of the shaft does not allow the assembly to be pulled out the top with the gears attached.
So, how exactly does one pull these gears off the shaft with no room to work inside the headstock??
Thanks
Glenn
Thanks
Glenn
