I heard using old cast iron exercise weights for project material can be a crap shoot but wondered if anyone has any experience good or bad?
Been looking for a piece of material for a upcoming project that I think could be made from cast iron or steel. Looking at my usual source, the scrap yard, I was finging pieces of steel round too small or too large and no cast stuff even close. Today I found an old cast iron exercise weight that may work. It was a 30# hand weight that could be cut into two pieces and provide a second piece of material in case I mess up the first piece. I have attached a photo below of the weight after I cleaned off some of the rust and cut it in half.
The project is a backing plate for a lathe chuck and requires a finish diameter of 4.00 inches. The existing backing plate that came with the chuck has a spindle thread that is too small for the lathe I want to put it on and the hub is too small to bore out and thread larger. So I need to start with new material.
Anything I should know before I start?
Benny
The Orphanage Never Closes
Benny
