- Nov 14, 2014
- 851
Need help understanding how to use 3C collets in my Burke #4 vertical milling attachment.
Today, Got my vertical milling attachment set up and running today. Had fun milling down some stubs of welded on channel iron off some original castings. (No idea how the parts ended up being welded, but they did, and it was a stout, permanent weld).
I had one beat up 3C collet in my stash of spare and odd ball collet sizes. So was able to hold a 5/16” end mill to do the work.
So now the questions/problems:
End mill pulled out of the 3C collet, several times. No real harm done, but I want to mitigate this happening. I tightened the collet draw bar thingy with a crescent wrench as much as poss8ble. However, noticed the mouth of the collet fitting has a slot in the housing. Is this slot possibly used to hold a scanner wrench to the spindle to tighten the draw bar??
If not how does one immobilize the collet spindle to crank down on the draw bar more??
Here is a photo, hopefully showing the slot in the face of the collet holder.
