I own one 2" face mill with triangular HSS inserts. I have a fly cutter as well. I don't get the kind of finish out of it that I'd like on either. Best I seem to do is with really light cuts.
I've mostly used them on aluminum so far but have a project coming up in mild steel. Thinking about getting a face mill with circular inserts. Something along the lines of this https://www.ebay.com/i/183515058263.
On this project will need to face off mill scale on 2" A36 and (hopefully) get a good parallel surface.
I'm also wondering if I'd do better by replacing those triangular HSS inserts with carbide but I'm concerned about chipping on something like a face mill where it's going to be interrupted cuts quite often. That plus the better surface finish I "think" I'll get from the circular inserts is what's making me think to try that.
I'm sure some of what I'm doing wrong with both tools is about speeds and feeds and with the fly cutter I am sure my tool geometry is not optimal. Thing is I am not set up to grind tools. I know I'll be told it learn to do it but I use inserts a lot on my lathe work and just prefer the convenience of inserts. I know, sacralige right? I've invested quite a lot in insert tooling.
That said if anyone has any advice on how to run that face mill better and selecting insert geometry I'll take anything. This is on a 1-1/2 HP Bridgeport.
