- Dec 18, 2019
- 7,428
Sorry to bombard the forum with these simple questions. I have some 25mm OD carbon fiber tubing I'd like to hold in a 25mm collet. The collet is in a square collet block so I can drill holes in the tubing at right angles. The tubing obviously isn't exactly 25mm in diameter. I measured 24.99mm at one end and 25.04 at the other. (Using my junk calipers, since that's what at my desk.) The collet just scrapes the shiny gloss finish in places when I insert the tubing. Is there something I can use to minimize the gloss finish damage? Should I use lube? A wrap of thin film like saran wrap? Something else? Slightly spring the collet? Thanks.
