- Feb 7, 2014
- 350
Some time ago I did a quick and very dirty conversion of my little X2 mill. It was useful enough and worked well enough that I desired a first class conversion. Acquisition of a mill drill to make parts while the X2 was apart enabled the reconversion. The table is together and I should have the standoffs for the X-axis motor done tonight or tomorrow. It is time to decide what I am going to do with the column and head.
I could have really used the nod capabilities of a knee mill when I was milling the X and Y axis. but is there enough use for that capability in a CNC mill to re-manufacture the X2 head? Would a rotary 4th axis be a better project to waste time with?
The other thing I was thinking about doing was modifying the spindle saddle so that I could rotate the head 90deg. I used that capability on the mill/drill to do horizontal boring of the base, but again, would I ever want to write a program that ran with the spindle at an angle? Tramming is a whole lot easier on the mill drill by rotating the head than on the X2 by tilting the column. It may be a worth while modification just for that.
