Useful South Bend Lathe Files
HMF
Site Founder
Administrator
Sep 22, 2010
7,222
Here are some files for South Bend Lathe Owners:
  • Form 983B IMPORTANT4-5-65.pdf
  • Form 1038 Care of machine tools not in use.pdf
  • FRM928C Screed Feed Double CS 13-16-2H (1).pdf
  • FRM945A 2H Turret lathe Moor Control.pdf
  • FRM945B 2H Turret Lathe Motor Control.pdf
  • FRM979 13in Turret Base + Turnstile.pdf
  • FRM980 13in Turret Ram + Head.pdf
  • How to Run a Lathe 20 15th ed.pdf
  • Lubrication-Chart-6008-for-Heavy-10-and-up.pdf
  • lubrication_chart_6503.pdf
  • Installation and Leveling of the lathe (H3) a.pdf
Here's a great one that has been in my archives (they are scans of the actual books):
http://www.wewilliams.net/SBLibrary.htm
1914
3rd Ed
300 dpi
2.7 Mb
1914
15th Ed
300 dpi
3.0 Mb
1917
1917 Ed
300 dpi
5.0 Mb
May 1918
55
300 dpi
4.0 Mb
1920
2nd Ed
300 dpi
4.4 Mb
1920
1920 Ed
300 dpi
4.2 Mb
1925The Correct Way to Machine Oversize Pistons Bulletin No 85 400 dpi 4.5 Mb
1925 The South Bend Method for Refacing Valves in the Lathe Bulletin No 86 400 dpi 4.2 Mb
1925 South Bend Shop Methods for Electrical Service Stations Bulletin No 87 400 dpi 4.3 Mb
1925 The South Bend Method for Reboring and Regrinding Cylinders in a Lathe Bulletin No 89 400 dpi 4.1 Mb
1928 New Model South Bend Brake Drum Lathe Bulletin No 29 400 dpi 16.0 Mb
1928 South Bend Machine Shop Course Bulletin No 55 400 dpi 8.0 Mb
1929 Auto Mechanics Service Book No 66 400 dpi 14.9 Mb
1929 South Bend Hand Book No 33-C Showing Shop Kinks for the Auto Mechanic Hand Book No 33-C 400 dpi 15.0 Mb
1929 South Bend Hand Book No 44 for the Mechanic Hand Book No 44 400 dpi 15.1 Mb
1930 South Bend Hand Book No 33 for the Auto Mechanic Hand Book No 33 400 dpi 14.9 Mb
1931Latest Shop Practice Bulletin No 30 400 dpi 5.8 Mb
1931The Small General Shop Bulletin No 50 400 dpi 3.9 Mb
New01.gif1932 How to Grind Valves in the Auto Service Shop Bulletin No. 1 600 dpi 2.1 Mb
1932South Bend Lathes for Auto Service Shops Circular No 36 400 dpi 2.9 Mb
New01.gif1933 How to Make Bushings in the Auto Repair and Electrical Shop Bulletin No. 7 600 dpi 1.4 Mb
New01.gif1933 How to Test and True Differentials in the Auto Repair Shop Bulletin No. 5 600 dpi 1.4 Mb
New01.gif1935 Interesting Installations of South Bend Lathes Book 71 600 dpi 19 Mb
1935Repair Parts for South Bend Lathes Bulletin 19-B 400 dpi 5.4 Mb
1936How to Grind Valves Bulletin 1A 400 dpi 2.3 Mb
1936 How to True Armatures Bulletin 2A 400 dpi 2.1 Mb
1936
No 4A
300 dpi
2.0 Mb
1936 How to Test and True Differentials Bulletin 5-A 400 dpi 1.6 Mb
1936How to Bore Rebabbitted Connecting Rods Bulletin 6-C 400 dpi 2.2 Mb
1936How to Finish Pistons Bulletin No 9 400 dpi 2.2 Mb
1936
Bulletin No. 34
300 dpi
1.0 Mb
1936 How to Cut Screw Threads in the Lathe Bulletin 36A 400 dpi 3.5 Mb
1939Farm Mechanics in the School Bulletin No 31-A 400 dpi 4.9 Mb
1941
38th Ed
300 dpi
6.7 Mb
1940
37th Ed
300 dpi
6.7 Mb
New01.gif1947 Curso Elementry de Instrucoes para o Ensino de Aprendizes de Torneiro Mecanico Livro 30-P 600 dpi 12.7 Mb
1953
52nd Ed
300 dpi
6.3 Mb
1954 School Shop Planning and Specifications Manual 400 dpi 50.0 Mb
Form 1178
300 dpi
1.0 Mb
How to Install and Operate a South Bend Precision Vertical Milling Machine Bulletin 6012 400 dpi 2.3 Mb
NON-LINEAR SCREW CUTTING ATTACHMENT - FOR 9-INCH SOUTH BEND LATHE 400 dpi 3.0 Mb
Bulletin No 600
300 dpi
3.0 Mb
C-161
300 dpi
0.1 Mb
EP-100
300 dpi
0.1 Mb
June 1978
Jeff Swayze Collection: South Bend Lathe Price List
1.5 Mb
Jeff Swayze Collection: South Bend Lathe Accessories Catalog -
7.6 Mb
MetalWorking.com: South Bend 7" Shaper Model CS100
0.6 Mb
MetalWorking.com: South Bend 9" Lathe Model CL 670Z
1.3 Mb
I "googled" South Bend gearing & located some excellent data in PDF form. The data gives very concise definitions, gear ratios for headstock, QCGB and apron. The submission appears to be public domain. here it is bnordgren.org/files/model-a-gears.pdf.
There are also some excellent diagrams.
