- Feb 1, 2015
- 9,948
My 4x6 bandsaw actually can only cut a 5" wide piece due to the placement of the front vise jaw. I replaced the front jaw with a 6" length of 3/4" x 3/4" hot rolled bar and gained an extra 1-1/4" of capacity. The bar is mounted with two 5/16-18 socket head cap screws in two new threaded holes on the saw table. This leaves the OEM vise jaw still usable for when I need to make angled cuts.
Another useful trick is to use step clamps for clamping work to the table. My 9/16" T nuts fit nicely in the slot for the back vise jaw. This enables cutting short pieces which would otherwise be difficult to clamp with the OEM vise jaw. Two step clamps can be used to clamp irregular work.
