Used indicators and other measuring tools, what to look for?
Investigator
H-M Supporter - Gold Member
Jun 8, 2016
640
I have the typical 'new guy' Chinese dial and test indicators. I'm getting to the point that I want to buy some better quality. I have seen items for sale on the bay or local groups as well as pawn shops. My question is how do I know they are still in good shape? Do they go out of spec, is there a way to test or tell before spending money on them? Or is it more of if they function they should be fine?
How do I avoid buying damaged tools?
My opinion is that, looking at how the internals actually work, if they move smoothly, return quickly and all the dials rotate as expected, they’re fine.
Ebay if the seller has a ton of good reviews, I also look for the brand, and type I'm looking for under "refurbished". Repair companies will often have refurbished metrology tools in stock.
https://www.ebay.com/itm/NEW-Calibr...773246?hash=item21716b397e:g:VEoAAOSwphFe7ok9 . I have bought several indicators from this ebay seller: hugomac13 and they work well are calibrated but cost more. Lately he hasn't had too much variety. There are a few others that other members may be able to chime in as to their names.
And return to zero. This is often the problem I find. If they don’t, I pass. All my DI’s and TI’s are used. And the best of them have old calibration stickers on them.
I have had bad luck with name brand indicators and other measuring tools bought used. They either have something wrong or something goes wrong quickly. On the other hand, I have had good luck with import measuring tools bought new. They look blocky, and can be a little balky, but they work. The old name-brand stuff looks so much better, though. If you send a Starrett in for repair, the cost is much higher than if you just bought a Harbor Freight or some other cheapie.
I like used Ames and Federal indicators. They seem to be built like tanks and usually have very few issues if any.
I think your questions deserve serious answers because a lot of hobby guys have the same concerns. While I am not an expert at this stuff I have been buying tools on ebay almost since its inception so I'll offer some opinions.
If I could give a new hobby guy some sound advice it would be to buy a known good instrument new; buy it once and cry once. If you need a source to determine which is the best for your needs, go to the Long Island Indicator Service site and do some homework. Then search for an authorized seller with the best price; the purchase will provide the documentation required for warranty coverage. Good tools can last a lifetime, will typically be accurate over that time and can be repaired and recalibrated if needed. I can tell you for sure that there is a difference in the feel, smoothness of action and accuracy between a good Swiss indicator and the rest, including Mitutoyo.
Okay, what to look for on ebay:
  • Know what you want and only buy that one thing. If it isn't there now, it will be soon so wait for it.
  • An indicator that is in really good condition will look that way. If it is dirty and the dovetails that the holder fits on are scuffed up and damaged then pass on it, even if the price is good. A filthy indicator has been used a lot and if it is filthy then it was used by someone who doesn't care about it. On the other hand, an indicator that is clean even in the smallest spaces and has pristine dovetails and a clear crystal is probably a good candidate. Contact the seller and ask if there are any issues with the indicator. If there are no issues then ask what his bottom line price would be; it will usually be lower than the listed price and you can make a deal, sometimes a very good deal.
  • Try hard to buy indicators that come in a case with all the accessories that usually accompany a new indicator. If the user sells it like this then he probably took good care of it during its working life. The guys who care about their tools will take the indicator from the box and use it, then put it back in the box when they're done. The box may show some wear but the tool should not. That is the kind of seller you're looking for.
  • Look hard for signs the tool was dropped. Good indicators are built to be used so the internals are pretty tough. However, they are not meant to be dropped onto a concrete floor so if you see signs of damaged dovetails, pass. The dovetails on a Swiss indicator are usually hardened steel and they can crack. On some, like Interapids, these can also be removed and replaced so an otherwise pristine indicator may not be a bad buy but only if the internals work as they should. I usually pass on dropped tools.
  • A calibration sticker tells you the tool was used in a professional shop. It tells you nothing about the user but it is likely that the tool was well used. That doesn't mean it isn't a good buy but it does suggest it saw some regular use. If it was treated well, it will look like it was. If the crystal is scratched up and there is oil around the bearing at the nose of the tool then it spent its life in an indicator holder and crap was just wiped off during use. Pass on these.
  • Buying on ebay is usually the best bet but don't overlook Amazon. Sometimes you can buy a brand new tool on Amazon for just a tiny bit more than a used one on ebay so make sure you look around. Typically, Amazon will beat Long Island Indicator for new tools of all makes.
  • Buy tools that can be repaired and calibrated. Most import stuff is not worth the repair cost but the good Swiss ones are. You can have a good DTI cleaned, serviced, calibrated and returned to full working condition for half of what a new one would cost.
  • Ebay favors the buyer, not the seller. If an indicator is sold as "used" or in "good" condition then by ebay's definition, the tool must work properly and fully. If it does not then you can return it at the seller's expense. Period. It is also wise to use Paypal because they will work to recover your money in the event of a dispute.
  • Always try to contact the seller to confirm the condition of a tool you are interested in. This leaves a trail for ebay and Paypal to follow a transaction. If the seller says the tool is in good condition and fully functional then it is on him to make sure it is. Otherwise, you can send it back at his expense, risk free to you. I have had contacts with guys who I got along with really well and more often than not, I got a better price than the listed price because I took the time to contact them. Don't overlook the power of an email.
  • Be patient. The tool you want is either on ebay or will be at some point. For example, this year alone I have found 3 Compac 215GA tenths reading indicators with extended travel and large dials. This tool sells for about $300.00 new. Each one I found sold for a third or less of that and all worked well and were in good condition. My best personal find on this tool was about 5 or 6 years ago; a mint condition 215GA that I got for $50.00. If you are patient and know what you want, you will eventually find it and it will often be less than a Chinese equivalent.
Okay, hope this helps.
Have a look at these folks under "Used/Demo". I bought a refurb'd micrometer from them and was happy.
I also bought a used mic from eBay that was in perfect condition at a bargain price. I would watch for a tool that looks
essentially new, especially if the description matches what you see. It's a risk, but there are lots of good tools on eBay:
just aim for quality and not for a cheap price. Be patient. I also believe that folks that pay for a good quality too in the
first place will tend to take better care of them. I don't know about where you live, but CL has lots of decent looking
tools to look at as well, although I know some folks think they're gold plated for some reason!
Patience and knowledge. Know the quality names. I’ve gotten insanely lucky and bumbled onto deals. Like a guy came into work where there were few real mechanics and he’s got this junction box full of DI’s, a TI and a B&S 2-3” mic. He hit me up first because I was one of the few who even knew what they were. But the work we did(assembly) there was no use. He wanted $75 and I laughed, so he went around and asked the 50 guys on the floor and no hits.
So he decided he was going to harangue me into it. I didn’t want or need them and he wouldn’t take no so I said $20, of course he acted offended, but took it. It would be almost 15yrs later in a thread on another site where somebody pointed out the TI was a .0001 Alina. Never heard of it but it is highly regarded. Dumb luck. The Ames was broken, 2 Starrett .0005’s, a Federal .0005, Alina and the B&S 202 mic. Starretts work perfect as does the Federal and the Alina. The 202 has something wrong with the clockwork and works intermittently. Not bad for $20.
