- Feb 28, 2019
- 530
I've been messing with taper pins and actually like them for assembly and alignment. So I decided to try a 2" long #0 taper pin.
The thing is that I can't find a reamer that covers the whole length of the taper (at least on McMaster-Carr). I'm guessing that people tend not to use long tapers.
So how would one go about reaming a long taper hole if it requires two reamers?
Is this easily done by feel?
I assume that you would ream the deepest smallest part first and then the larger upper part, but how do you know how far to go and not create a ridge?
Or is it crazy to try this and the answer is don't use long small taper pins because long small reamers are hard to find and expensive?
-Dave
-Dave
