Hi,
Has anyone made a spindle mount for a variety of different work "wheels" (ie wire, hard pollishers, suft pollisher, buffs)
I have 3 differnet bench grinders set up. One has typical 2 different stones, one has 2 different wire wheels, and one 2 different hard buffing wheels.
The 2 with the stones and wires never got changed out, I think thats typical, but when pollishing something, theres the wheel for the red compound, and one for each of the white, green, blah blah blah. PIA always changing them up, even though I dont do tooo much pollishing.
So last week one of my grinders calls it quits!!
Ive seen it somewhere in the past, with a wack of wheels mounted on one long spindle, with 2 different motors and pulleys. For slower speed, use motor "A" mounted at one end of the spindle (with a pulley).
For higher speed, use motor "B" mounted at the other end of the spindle with the corresponding pulley for appropriate speed. With either motor running the other just tags along as an idler. The other option could be to use a DC motor with a variable speed controller.
But for pollishing the important factors are speed and force applied to the wheel, so need a VERY torquey motor.
I dont know much about V/Speed DC motors and torque levels.
ANYhow, the above description is best picture I can describe to something I saw several years ago. The ability to go from one wheel to the next, and next etc is ideal.
Anyone have or built one of these?????
Cheers all,
Ken J
Cheers all,
Ken J
