In some cases, it's a two stage process, but I use a 1" indicator in most instances. The face must run true first, generally, then the OD or ID (whichever I'm working on). It may take a few switchouts between the face and the OD/ID, but unless I need to reach into a very small area, the 1" indicator will do. If not, I have some extension points for it, or once I get close, I use a test indicator.
