@ycroosh
I have been working with two TDRO installations, using one tablet for the display and I'd like to offer some feedback and ask for an enhancement or info on how to do it right if I'm not doing so.
What I am speaking about is re-connection with the scale adapter associated with a machine (configuration) when I switch. Currently, upon changing configurations (e.g. mill to lathe) I pick the config from the TDRO menu but I then have to fiddle with the BT address selector (BT icon in the upper right corner of the screen) to change scale adapters. Usually it means trying more than once to get an adapter to respond. It would be convenient to have the BT address pre-selected by the config so it just connects to the right adapter when the config choice is made. It could remain selectable manually as well if needed.
Am I also correct that I cannot re-name the scale adapter within TDRO so that I don't have to remember the BT address code in order to choose the right adapter? I can re-name it under Settings/Connected Devices but the name does not pass through to TDRO and I'm drawing a blank for changing it within the app.
Thanks!
D
Thanks!
D
