- Apr 14, 2014
- 3,472
I stopped by one of my favorite used equipment dealers earlier today and found a type of comparator stand I'd never seen before. I'm not sure if it's a shop made tool or from a major manufacturer. There doesn't appear to be any identification marks on either the steel or granite portions.
It looks like a well-built tool. Coarse adjustments are made by loosening both the thumb wheels on the right side and raising or lowering the indicator and hardware on the post. Once the coarse adjustment is made the upper thumb wheel is tightened. The fine adjustment is then made by rotating the horizontal brass thumbwheel. Once the desired height is set it's a simple matter of tightening the lower thumb wheel and passing the part under the indicator to determining the actual height.
The indicator position can be adjusted using the knurled ring closest to the solid fixture on the post. It will swivel 360* and approximately 15* off vertical or horizontal. It must have been used to measure parts that needed a fair level of precision since the indicator measures in .0001" increments.
I see both Federal and Starrett made similar comparator stands. However, there are enough differences between those and this one I doubt it was made by either company.
