Unknown drill press
GK1918
Nov 21, 2010
1,602
I tried to post a pic of this but It didnt work. This is the one with a belt about 18' long. There are
no numbers or mfg. markings. MT 2 quill that is indexable and the table will drop to the floor. About
8' high. The belt runs from the quill horizontal then twisted to two idlers then down to a four step
cone pulley then from that down to the motor. All flat belt. It does well with an end mill, because it
is so rugged absolutly no flexing like imported junk made from pressed tin. All solid cast .
Hope this works. Sam
I forgot to add that you can see this red belt I made vertical behind the cover and the nicely made
mesh motor drive cover. I wanted more pics but my camara batt went dead. Thanks sam
Might want to see over at the OWWM site where there is lots of pics. I would guess Buffalo...Bob
Looks a little like the Cincinnati/Beckford I have.It has a few things in common.
Paul
