UNIQUE REPEATABLE ADJUSTABLE CHAMFER STOP
Parlo
Feb 21, 2022
849
Following on from the precision solid stop milling vise square, this unique 45 degree setting tool makes light work of machining repeatable, accurate & fast chamfers.Having the end stop on the stock prevents the whole unit from slipping along the vise when pressure is applied downwards on the part. This allows holding the part solid & accurately on the blade against the adjustable blade stop with just one hand. Then the other free hand can tighten the vise.The video also highlights the benefits of having a rotating end stop that holds the X datum in position & the speed advantages of using various thickness quill stop spacers.
