Had one of those for many years. '69 to about 2004... Well, what I had was a DB-200, functionally the same with a different nameplate. The spring on the headstock is a return spring for when you need to move the spindle. It will feel loose, I never noticed if it would spin around. As a drill press is the most common use but there are other uses. Once you get to know the machine, there are many "uncommon" things it will do. I didn't get the riser post or the bracket when I bought mine. "Petty Officer Hall" made one for me, what he felt like it should look like. I stumbled across one some 20 years later... and snapped it up. Eventually acquired another machine. But no book, blah. Heard of a fellow once who used it as a hand drill. But I already had a hand drill so never tried it.
Cutting tapers was one of the most useful jobs to me. Just pull the pin and swivel the headstock. I had one taper to cut regularly so drilled a second hole in the frame to set the pin back in. The power feed is a good accessory, for cutting. Not worth a da@@ for threading. That's why it got replaced with a larger machine. Then the 6X12s (Chinese) came along and things started getting really crazy.
Mine came from a pawn(?) shop in California in '69. No box, no manual, no tooling. I had to figure out everything for myself. In those days, there wasn't much understanding of the difference between M6X1 fasteners and 1/4-20 &-28 we had on the ship. Not even the ship's machinist had any ideas in those days. But I learned a little here and some more there and eventually had a usable machine.
Something to take note of; There are several small 3 jaw lathe chucks around. The UniMat has M12X1 threads on both the headstock and the tailstock. Some of the parts floating around have M13 or M14 threads. It is NOT 1/2-20, although to an untrained eye it sure looks like it. I bought a tap and die in the appropriate size, made a few "accessories"...
I still use the chucks on occasion on the big (to me) machine. I now have a Craftsman 12X36, MT-3 on the headstock. I made an adaptor of sorts, took a MT-3 to Jacobs and cut it down to M12X1 so I could do my small jobs. The smallest most of my chucks will go is 1/8th inch. I have motor shafts and axles in the M2.5 range, about 0.100. So, out come the UniMat chucks, on such a huge machine. It looks preposterous, a 75mm chuck on a 12" lathe. But it works for my small work.
