Unenclosed 1/2 HP cherrying head motor mount repair
tfleming
H-M Supporter - Gold Member
Nov 21, 2015
226
Thought I would share a little repair that is in progress. Working on cleaning up and resurrecting the Cherrying head I bought at auction a few weeks back. Broken pivot slot on the motor base:
Filler piece milled, ground, and filed from a 3/8" piece cut off 3" ductile iron rod I had in stock:
Rough fit for brazing tomorrow:
After brazing will visit a friend whose Bridgeport is up and running, to clean up around the repair. Should turn out just fine. Will post finished pictures when done.
SB, I found a cast iron wheel blank on McMaster that should work out just fine. 9" diameter. unfinished casting. It will be a wee bit before I get to that point, as I have almost totally disassembled the blasted thing......sat in high humidity for too long. It absolutely can be saved, but she is all in pieces, and being cleaned and de-rusted as I go. I'll try to get a few pics if I can.
I wondered while looking at my new grizzly catalog , they have some nice cast iron handles at good prices. Like $25 for a complete two piece set. Spinner and handle. Good luck with the restoration.
SD, thanks, I'll check them out. The McMaster one is just a "as cast" wheel, that needs to have the hub machined. It does have the handle on it though. I'll check Grizzly out before I take the plunge. McMaster wants $80 + shipping for it. While I am willing to spend the cabbage, I also wouldn't mind not spending 4 Jacksons +..............................either way, I need to get one at some point.
Now, off to my friends house to mill and clean this up a wee bit (unless he can't), then it's me and the die grinder! LOL.
Looks like a good, solid repair. I wouldn't bother with the mill. Hit the high spots with die grinder, and finish with a flap wheel, or sanding disc. Mike
I agree , might cause more damage trying to set it up. Couple shots with a grinder, and file or scotch brite and go to the next part.
thanks guys, maybe I'll just do the die grinder approach and finish off with the flapper disc.
I think this will work. I did shatter my 1/4" carbide burr on it. I put the 1/2" one in to finish. While not perfect, it will be very serviceable.
