- Oct 19, 2020
- 160
As you can tell from these questions, I am entirely new to running a lathe. I am getting ready to turn my South Bend 10k on for the first time and would like some advice to avoid causing damage. Here are a few questions:
Q1: What would happen if I accidentally turned on the lathe with back gears engaged and bull gear pin engaged also?
Q2: What would happen if I accidentally turned on the lathe with my bull gear pin disengaged and back gears disengaged?
Q3: Is it proper to turn on the motor with the belts already tightened or is it better to turn on the motor and then tighten the belt?
Thanks for your advice.
