- Nov 8, 2011
- 1
I am new to machining, and learning as I go.
So I have a question. I need to bore a hole in a part, and attach a shaft to it. It will NOT have a set screw holding the part.
So it will be a press fit.
My question is how much smaller should the hole be compared to the shaft?
So if the shaft is .500", what should be the hole? I tried .499, but it's seems to not be enought, as the shaft can turn.
Thanks,
Jim
Thanks,
Jim
