Unaflow Steam Model Engine
cascao
May 24, 2012
395
I'm in a process of making one as Elmer's plans.
Since I don't have a mill, sometimes I have to be creavive or use caveman tools like handsaw and files.
1mm diameter hole on conecting rod 2mm pin
Parting Engine head
Conecting rod
Governor
First trial pre assembly still missing the cylinder and valve
Looking nice, Waiting for the finished running project. And they use to make things without mills all the time,
Wow. I think these smaller things are harder to make properly than gargantuan stuff. Looking good!
Have done the cylinder !
Missing piston, valve and rod guide which will be in Nylon.
And flywheel. Will try do it with spokes :eek:
You have a lot of patience and a talented hand my friend!
That is an interesting vise (in the "Milling Time" pictures). Could you include a better picture of it and maybe some info on it? I've never seen one like that - but I lead a sheltered life!
thanks!
It's my "scrapyard milling attachment" basically it's a old lathe top slide mounted in an angle plate to give me the Z axis. It was discussed on: http://www.hobby-machinist.com/threads/scrapyard-milling-attachment.38416/#post-345893
Here me, milling steam intake ports yestarday:
