Attempting to swivel the head to vertical (from the as-shipped orientation) and it’s bound up at 37 degrees. All 4 head mounting bolts are just-loose, and head is supported while swiveling, per the manual. I've tried supporting it/taking weight off the joint from different angles, but nothing so far seems to work. The supporting load is aligned with the joint, and perpendicular to the swivel-axis (of rotation), so there should be no binding moments being introduced that way.
PM tech support advises that I back off to ~ 45 degrees, jiggle the head some, then try again to advance it. One challenge is “jiggling” a 200#+ part that is 7' up, off the floor. But with the jiggling I am able to do, I can feel relative motion between the head and the ram when it’s backed up to 45 degrees, but all that motion stops when I reach the bind-point (37 degrees). As it binds, I’m finding 1 or 2 of the head mounting bolts have snugged just to the point of no longer free-turning. Using a wrench to back them off just a few degrees frees them again, but it doesn’t fix the binding issue. PM's response to this is to try removing the head mounting bolt(s) that has become stuck, 1 at a time, to free any jams/binding they might be causing. I tried backing them way out, 1 at a time, but no joy so far. Any attempt to advance further results in a different head bolt becoming snugged. So, I’m stuck at 37 degrees, literally.
I’ll be back on the phone with PM tomorrow, but figured I throw this up on the forum in the meantime, in case anyone has similar experience or other suggestions for how to resolve this issue. I’ve thrown in a pic showing where I’m at.
