- Nov 8, 2011
- 1,678
My buddy needed the lift for his hoover craft tweaked so I made a cup/spacer/shim to go over a bearing and do 2 things, make the bearing fit snugly in the tubing and make it set on the bottom of a solid piece so it would actually function. I need to make another shim for the top but it will be a bit more difficult as there will be no bottom in it to help keep it in the chuck.
