Last December I bought a dirty Index 645 mill that otherwise seemed to be in decent condition for the price. It has had some noise while running since I got the electrical box built, running a VFD. Right off the bat I ran just the motor with no belts. It's whisper quiet. The first pulley set off of the belt made some noise so I removed that assembly and gave it new bearings. It's only an intermediate pulley set that doesn't affect precision so I gave it standard grade Timken bearings. That made it somewhat quieter so I was happy enough for the time being.
There are 5 bearings in the quill and spindle and one or more of them clearly was an offender. I've been trying to nurse the machine along and continue to use it but in the last week or two the noise has gotten much worse. I pulled the drive sleeve and bearing assembly beneath the spindle pulley and gave the spindle a twist by hand. Yes, there was the rough rumble that was getting worse. I made a pin wrench to remove the threaded rings that set the preload and lock it in place but the lock ring didn't want to budge with the maximum pressure I was willing to exert. I would rather send it to Well-Index as is than mess up something and make for an even more expensive repair. The spindle drive bearings are not high precision so they were also replaced with standard Timken bearings.
In the process of cleaning up I removed about a half pound of nasty old grease that didn't even need to be there. Now I know why the spindle was leaking oil. It was all of that grease "sweating" out of the oil.
The quill and spindle assembly is out of the head and will be going to Wells-Index for an expensive visit. Bearings and installation runs just over $700. If there is runout in the spindle bore then regrinding it will run another $237.50. It's a painful amount of money for a hobby machine that generates no income but it's the only way to go. Letting Wells-Index do the repair should restore the machine to their new standard of 0.0002" runout. Glad I haven't sold my mill-drill yet so I'm not totally without a mill for the interim.
